Sorry didn't see this, lots happening also.
The above guide is spot on. Don't forget to do this prior to installing any components, so leave CPU/RAM/SSD out until you have completed the flashing process.
Also have some patience when you are flashing it, it can take 3-6 minutes, and the first boot can take a couple of minutes also with several resets in between, once you have it all plugged in obviously. I'd advise to complete the first boot with only RAM and CPU installed and do it outside of your case to save time for further checking and testing just in case something does seem wrong.
