B450 Tomahawk - Quick Question
17 Feb 2009
Will be installing a new AIO soon.
Question is. There is a cable which connects to the CPU or Pump header ( pretty sure it can be either because my current one connects to the pump header and then the fans on the rad connect to the CPU header with a splitter )
So, I know some mobo will not boot unless something is connected to the CPU fan header. Is that the case with the B450 ?? Ideally I want to leave the CPU header empty, and plug the AIO into the Pump Header, purely for aesthetics
Thanks
Thanks
You can disable the CPU header in the bios, or set it to ignore to get past the F1 boot error.
Yeah it was already set to disabled. Thanks.
Installed it all no problems into the pump header.
Odd thing since not using the CPU fan header, the PC boots way quicker
