Hi all
My 8 year old i7 920 @ 4GHz / Gigabyte EX58-Extreme / 12GB DDR3 is showing its age (e.g Warzone, BF5, PUBG), it’s also struggling to hold a stable overclock these days (could just be old thermal paste haven't done it in a while!).
Looking for validation on any issues with the below build coming in just under £600 for MOBO, CPU, RAM and SSD with a view to certain upgrades next year, plus maybe some one else might find my reasoning useful.
I’m holding out for RDNA 2/Ampere next year so will bring across my existing EVGA RTX 2060 and 500GB SSD as a second game storage drive. I'm re-using my Lian Li v2100 so can go full ATX. Since PSU’s are having stock issues I’m going to trust my Corsair TX650 can last another 12 months and then update it.
I've just nabbed an LG 27GL850 so I'm looking exclusively for gaming at 1440p/144Hz (or close as) Connectivity wise I’d like WiFi as I’m currently using an older Asus access point as I can't go wired, so makes sense to get it baked into the board, I’m just a little concerned I’m reducing my choices in doing so. Otherwise not looking for anything special such as RGB but see my reasons for B550 and the specific board in mind.
I’ve chosen B550 over X570/B450 for the following reasons:
From bewildering 49 boards that were launched I've finalised the below WiFi ATX versions as they’re currently in a similar price bracket (granted a bit more than I hoped to spend, but for £10-15 WiFi premium isn't bad), I’ve called out what I noticed as a differences in each:
Weighing up 3300X vs 3600, I’ll likely go for the Zen 3 equivalent of the 3700X when it’s out next year so since this is more a stop gap I’m guessing it makes sense to opt for the 3300X?
[Edit] Intending on using the stock cooler either way as I'm not looking to over clock and it saves on budget
RAM
I was then trying to follow the ASUS QVL, the only reasonable options seem to be Corsair LPX 3200 CL 16 or 3600 CL18 which using the simplistic speed formula I've seen elsewhere ((CL / MHz)*1000) both are the same speed so go for the cheaper I guess? Otherwise I'm open for any suggestions on 3600 CL16-14 in a similar price bracket but can't see any from the QVL?
So the build...
Reusing:
Case: Lian Li v2100 ATX / E-ATX
PSU: TX650 V2 650W Enthusiast Series (Until next year)
GPU: EVGA Nvidia GeForce RTX 2060 6GB XC Ultra Turing (Until next year)
SSD: Crucial 480GB (Second gaming drive)
New:
My basket at Overclockers UK:
Next Year:
PSU: When PSUs stock get back maybe the RM SERIES RM650 650W '80 PLUS GOLD'?
CPU: Ryzen Zen 3 4K series (3700X equivalent)
GPU: RDNA 2 / Ampere
SSD: PCIe 4.0 M.2 NVMe (When they're cheaper and more abundant, the new 1TB M.2 will then become second gaming drive)
Thanks
- Still a bit cheaper than X570 unless anyone can match the Asus with Wifi?
- Beats B450 with PCIe 4.0 on both GPU, SSD and sets up for Zen 3 4k series + RDNA 2/Ampere + cheaper 4.0 NVMe drives in 2021
- This is also the reason for CPU choice
- Nice to have x2 M.2 drives
- Yes AMD backtracked on B450 Zen 3 support but seems like a lottery with the one way flashing considering I'm buying new?
- I’m less likely to tinker with overclocking, not that Ryzen appears to get that much benefit anyway, maybe Zen 3 will change that?
- Not likely to do SLI/Crossfire
- £209 ASUS ROG STRIX B550-F Gaming WiFi
- Good early review apparently
- Better S1220A Audio
- Wifi 6
- £194 MSI MPG B550 Gaming Edge WiFi
- X570 version had poor review so will this be the same?
- Worse ALC1200 Audio
- £204 Gigabyte B550 AORUS PRO AC
- Can't find a review yet but Wifi 5 seems like a dropped ball for the same price bracket as the others, can't see any other reason to opt for this one?
- Alternatives I dismissed were much cheaper Asrock B550 Phantom Gaming 4 AC ATX (OcUk only do the ITX version) or Non WiFi B550 with a WiFi M.2 module/PCIe card
- Can't see how buying another Ethernet AP wouldnt save the difference on a cheaper B550 board
RAM
So the build...
Reusing:
New:
- 1 x Asus ROG Strix B550-F Gaming (Wi-Fi) (AMD AM4) B550 ATX Motherboard= £209.99
- 1 x Corsair Vengeance LPX Black 16GB (2x8GB) 3200 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit= £79.99
- 1 x AMD Ryzen 3 3300X Quad Core 4.3GHz (Socket AM4) Processor - Retail= £149.99
- 1 x WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)= £134.99
Next Year:
Thanks
