B650E Aorus Elite always powering USB devices
3 Jan 2018
Brighton
So we recently upgraded my wifes PC to AM5 and went for the B650E Aorus Elite ICE, but my only gripe so far is how tricky it is to stop it powering USB devices after shutdown... I've got fast start-up disabled in both BIOS and Windows and I've tried hunting any USB settings in BIOS but it seems like nothing prevents the Unicorn poop from continuing to sparkle after shutdown.
I'm currently having to turn off at the wall or with the PSU switch to turn off the extra RGB devices, and sometimes even the AIO stays lit.
Any ideas on where else I can look?
Bit confused
Is the usb or the rgb the issue?
Or 2 separate problems?
For rgb staying on
Look in the motherboard rgb software
Happens on asus boards with armoury crate installed
If you don't set the shutdown effect to blank
Look for something similar
There's RGB devices (primarily mouse mat and headset stand) which are powered via USB and are seemingly still powered after shutdown, however on the X99 system this wasn't a problem. I've disabled everything in the BIOS that looks like it's to do with USB power, and I know fast startup can cause similar issues so that's disabled.
I'll have to take a look at GCC, but it's been an issue since before installing any of the software.
Look in the bios
Not had a gigabyte board in a while
Might be power management section
See if ERP is enabled or disabled
Some motherboards only have enable and disable
Some have more granular control allowing more specific options
Look in the bios
ERP was disabled by default, and I checked it again and both fast boot and ERP are disabled, can't see to find anything obvious unless I'm being really dumb...
There's no settings in GCC I can find either
Enable ERP
Hey sorry, haven't been around for a while.
I enabled ERP today and same thing. RGB devices still powered after a shutdown. Here's a photo of what I mean.
Keyboard, mouse and internals (ram, AIO etc) turn off, but mouse mat and stand stay lit, both of which are a single USB to the board. I feel like I'm missing something silly...
Tried different usb ports?
Including front ports out of curiosity
It may be plugged into a port that allows charging
When pc is off for mobile etc charging
On/off charge
Or whatever gigabyte calls theirs
On/off charge
Okay so I've enabled ERP and tried multiple ports, same thing.
I have got the headset stand plugged into her keyboard pass through though. The keyboard isn't lit, but it's still passing power :confused:
These are the only things I can see in the manual, that I'd change:
AC BACK = always off
ErP = enabled
Resume by alarm = disabled
LEDs in sleep, hibernation and soft off = off
ErP = enabled
Aah biscuits. Went back into the BIOS after last time when I turned ERP on... It was off :| turned it back on, done a fresh shutdown and all the RGB is off! At last!
Thanks for the patience
Got there in the end
Did wonder why erp enabled didn't cure it before
Erp is a sneaky bios function a lot of people
Are unaware of
It's fixed your rgb issue
Just be aware if you rely on things like
Power on by mouse,keyboard, or wake on lan etc
Those may no longer work with erp enabled
Unless you have a bios that allows more granular control
Of erp
