B650e strix
15 Sep 2007
Hi just had a 650 strix with a 7950X3D, assembled everything but on boot to windows stops because of security, needs to log on to microsoft but no internet?
I've checked, cables work, check bios its enabled, even tried disabling wifi, flashed bios to latest version, tried reinstall but stops as no internet.
Any ideas or is it an RMA.
Built a system with the ITX version of the same board, same issue. It's because there's no drivers for the network yet. On the "Let's connect you to a network" page, press Shift + F10 to open up command prompt. Then do the following command:
Code:
OOBE\BYPASSNRO
Windows will reboot, next time you get to the network page there should be a new option saying "I don't have internet". Continue with these steps, then when you get to the desktop you can install the network drivers (will need to download from another PC or phone).
Code:
OOBE\BYPASSNRO
Cheers Mate saved me a big bloody take apart. Many Thanks
