Hey guys.
I bought this board to run my 7600 with the option to upgrade to the 7800X3D at the back end of the year. I watched a video review of the board and I dont have any heat sinks.
Is this board OK or should I be considering upgrading - allI'm really bothered about is my FPS in games, i have noticed the board takes 30 seconds to get to the MSI screen then more or less instantly boots.
A guy on the MSI forum told me it was how AMD checks RAM.
My RAM is running fine BTW.
I've also seen that putting a heat sink on the board near the CPU is sometimes modded on - this wouldnt be a hard mod would it?
any tips - thanks.
any tips - thanks.
If all you do is game, I think it is fine, honestly. I do believe HUB's reviews are an important contribution, but their VRM tests are pretty hardcore for the average user. If you plan to run intensive stuff for hours with a higher-end CPU, then there's definitely a good reason to upgrade, but just for gaming? Nah. I'd say it matters more for higher-end PCs anyway because they are often water cooled and that doesn't send any air to the VRMs.
