I have been down the rabbit hole of reading up on all the latest and greatest, and have come a little stuck on my CPU platform of choice.
The long and short of it, is that I've always preferred AMD and I like that they stuck to a platform for a long time (AM5 will be their first change in many years, and will be the platform going forward for quite some time by all accounts). They also happen to be a bit cheaper.
Intel on the other hand already has a platform which supports DDR5, and while I dont intend to build a PC with DDR5 memory, I like the idea that I have the option to upgrade down the line, should I have the use case for it.
Now, my questions to you guys; Given that I don't "need" to immediately buy anything, should I wait it out for the Zen 4 processors, buy a Zen3 now, or build an intel 12th gen now? I will never overlock, if that's a consideration.
My specs that I was thinking is as follows but happy to take on suggestions, given the above;
5800x
Gigabyte x570
Corsair 32gb 3600mhz
Msi Rtx 3080
Gigabyte 850w gold fully modular
1tb nvme SSD
Coolermaster 360mm (3x RGB fans) watercooler
Lian li O11 Dynamic EVO
3x lianli RGB fans (total 6 fans)
5800x
Gigabyte x570
Msi Rtx 3080
1tb nvme SSD
