Hi all
Well, its been a while since I last posted and did any mods on my ASUS p5n-mx.
Current spec on my machine now is as follows
1) E2180 intel duo core (stock 2.0ghz) now overclocked to "2.8GHz) (40%)
2) Thermaltake Key 3 spirit (copper base and copper pipping,with aluminium fins - from base to tip is 8 inch)
when I bought this it had "machine" grooves in the copper base, which I found by sanding out thee machined grooves it decreased heat by a further 0.3 C)
3)akasa 120mm (rear exhaust) - sitting less than 1 inch away from the heatsink
4) 2x Thermaltake 80mm fans - side and front (induction/puling) air in, blowing over the hard drives, ram,graphics card, heatsink and board.
5) 500w Icute PSU (not the best by any means, but a huge improvement over the previous PSU) - also has a 140cm fan fitted, pulling hot air from the heatsink and the PSU PCB out of the back.)
6)1x 250gb hitachi hard drive( bought when I first built this back in 2007) 1x Western digital 2TB green caviar. and both are filled :lol:
7) Patriot 800mhz 2gb ram stick - 1x kingston 1gb 800mhz ram stick (my 2nd patriot failed and replaced with a kingston as a "temp" fix).
8) stock 2.0ghz 100% CPU/MEM load temps
"Core 1/core 2 = 19C
CPU = 19c
motherboard = 21c
GPU = 38
9) spec now overclocked
Field Value
Motherboard Properties
Motherboard ID 12/17/2007-MCP73V-P5N-MX-00
Motherboard Name Asus P5N-MX
Front Side Bus Properties
Bus Type Intel AGTL+
Bus Width 64-bit
Real Clock 280 MHz (QDR)
Effective Clock 1120 MHz
Bandwidth 8960 MB/s
Memory Bus Properties
Bus Type DDR2 SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 5:4
Real Clock 350 MHz (DDR)
Effective Clock 700 MHz
Bandwidth 5600 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 LGA775
Expansion Slots 2 PCI, 1 PCI-E x1, 1 PCI-E x16
RAM Slots 2 DDR2 DIMM
Integrated Devices Audio, Video, LAN
Form Factor Micro ATX
Motherboard Size 180 mm x 240 mm
Motherboard Chipset nForce7050-610i
Extra Features Q-Fan
temps now overclocked
Field Value
Sensor Properties
Sensor Type Winbond W83627DHG (ISA 290h)
GPU Sensor Type Diode (NV-Diode)
Chassis Intrusion Detected No
Temperatures (at 100& CPU and 80% mem load (converting some movies and listening to music, downloading/uploading etc etc)
Motherboard 41 °C (106 °F)
CPU 40 °C (104 °F)
CPU #1 / Core #1 34 °C (93 °F)
CPU #1 / Core #2 35 °C (95 °F)
MCP 60 °C (140 °F)
Aux 28 °C (82 °F)
GPU Diode 46 °C (115 °F)
Hitachi HDP725025GLA380 24 °C (75 °F)
WDC WD20EARS-00MVWB0 25 °C (77 °F)
Cooling Fans ( actually more fans connected than stated below - molex connected)
CPU 1156 RPM
GPU 50%
Voltage Values
CPU Core 1.272 V
Aux 3.696 V
+3.3 V 3.312 V
+5 V 5.564 V
+12 V 9.728 V
+5 V Standby 5.018 V
VBAT Battery 3.056 V
(some of the readouts above a little pessimistic :lol:- voltage core is pretty much correct though
the TJmax is 73.3c - maybe the cooling is a tad over kill :lol:
- from the specs above, any chance of being able to obtain an OC of 3.0ghz?
Thanks in advance
P.s Lashout Uk - is that a dolly sprint or 1850?
looks tidy from your sig - I had a 79 1300 in pageant blue up until a few weeks ago
Rob
CPU = 19c
motherboard = 21c
GPU = 38
Field Value
Bus Width 64-bit
Bandwidth 8960 MB/s
Bus Type DDR2 SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 5:4
Bandwidth 5600 MB/s
Field Value
Sensor Properties
CPU 40 °C (104 °F)
MCP 60 °C (140 °F)
Aux 28 °C (82 °F)
CPU 1156 RPM
GPU 50%
Voltage Values
CPU Core 1.272 V
Aux 3.696 V
+3.3 V 3.312 V
+5 V 5.564 V
+12 V 9.728 V
Thanks in advance
Rob
