** BACK IN STOCK AFTER A HUGE DELAY **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Our best selling Fan Controller is now back in stock after a long absence.
The Recon is a diverse and capable controller capable of much more than the average fan controllers.
not to mention the fact that it looks cooler than an Eskimo's pyjamas.
BitFenix Recon Internet-Connected Fan Controller (Black) @ £29.99 inc VAT
Take control of your system anywhere with the BitFenix Recon™ Fan Controller. This five channel fan controller features internet connectivity - another world first from the BitFenix Design Labs. Featuring dual processors that continuously interact with your motherboard, Recon enables you to monitor and control your system on the go with any internet-connected device, including the latest smartphone, tablet or laptop. The easy-to-use touchscreen displays your current system temperatures and status, while giving you easy access to Recon's robust functionality. Customizable profiles make it easy to save and recall your favorite settings, while the SofTouch™ bezel makes it an attractive addition to your killer rig.
- Internet Connected for Mobile Devices
- Touchscreen Controls
- Dual Processor Technology
- System Status Monitoring
- Five Channel Thermal Control
- Customizable Profiles
- BitFenix SofTouch™ Bezel
- Materials: SofTouch™, ABS Plastic, Steel
- Dimensions (WxHxD): 147 x 43 x 67mm
- Form Factor: 5.25" Drive Bay
- Fan Channels: x 5
- Temperature Channels: x 5
- Max Watts / Channel: 10W
- Measurement Frequency: Every 0.1 – 0.4 Seconds
- Temperature Alarm Range: 30 degrees - 90 dgrees
- Temperature Range: 0-100 degrees
- Screen Size: 4.7"
Only £29.99 inc VAT.
ORDER NOW
we also have it in white too :D
BitFenix Recon Internet-Connected Fan Controller (White) @ £29.99 inc VAT
- Fan Channels: x 5
- Screen Size: 4.7"
ORDER NOW
So you can save profiles, so it will ramp up fans automatically?
I have a "door", so I am looking for a fan controller that would do just that, but i'm not sure this could be it?
I like the idea of turning up a tornado fan to 100% while out of the room and not having to suffer the noise :D Quick blast of cold to wipe out the dust then back to sweet ambiance
Has it finally been completed and it works now :/ Been waiting so long but been too busy to keep up with it
I've been away for a few days but I am one of the developers of Phoebetria. I think many will agree that our software has been quite stable for quite sometime now. If there's something that wasn't working for you please let us know. We've just started with version 2 which is a complete rewrite, if there's something we can resolve we will try and get it into the rewrite. The only feature we haven't been able to provide yet is the remote access but that will also come in version 2 :)
Thanks for the reply just been playing with it today :) It works excellent!! Why wasn't something like this packed with the recon in the first place ill never know
Edit: Is there plans for any rainmeter addons for this digitalm3?
Edit: rainmeter isn't what I thought it was, I thought it was geared toward sensor readings. I will have to look at it further and respond properly. Maybe you can give me some info on specifically what you're looking to do?
I bought one of these and have been very impressed with it, its so much quieter now :)
Will it allow me to turn fans off, or how low will they drop? I've seen many won't go below 40%, which I would like them to.
Just ordered one of these in black :).
Is it possible to turn off the display on these? I see a power button but it isn't clear what it does.
Just for sensor reading really so u can have text on ur desktop with probe temps and current fan speeds. If you look at speedfan and its rainmeter addon something like that?
I have bitfenix spectre's paired with this and there max speed is about 1200rpm and i can get them down to 400rpm before they struggle to move. But u can turn any fan off or let the automatic controls run your fans but you need ur probes placed well for this mode to work
Yes if u press and hold the power button it turns the display off :) To turn it back on simply press the display anywere.
