Decided to get around to backing up my son's (win xp) eMachine netbook today. (as it doesn't come with a windows cd). Don't necessarily need to back the whole thing up, just creating a windows cd is all thats needed for recovery/reinstall.
Only thing I can find in the start menu is a tab (named after the netbook) for restore etc..
When I click on it I get to this option..
"Create Factory Default Disc"
Good I thought, I was going to do a backup onto a usb drive, however a para also states..
"It is important to create the factory default disc before using your pc"
Well the netbooks been used since xmas so I don't know if this will work now & don't want to try it in case it restores the netbook too.
Any thoughts? cheers..
