Backing up a PC using MS DOS.
20 Feb 2004
Blyth, Northumberland
Is it possible to backup a PC using MS DOS? If so how is it done?
I have an encrypted PC that won't boot and before I try to manually decrypt it I need to do a backup using DOS.
EDIT: The backup needs to be saved to a network location.
Well, if you have a NAS that's USB, plug that in, boot using USB mass storage drivers for DOS, then
copy *.* e:\
Surely that'd work!
Nope, copy won't do subdirectories. Need to use xcopy /s for that.
Is the machine FAT based? Remember DOS doesn't understand NTFS.
It's NTFS :(
My options at the moment are to decrypt the drive manually after backing it up or send it to a data recovery firm @ £900.
