Backing up data - whats the best way?
7 Feb 2004
As my hard drives are getting really full I was thinking about doing a big back up. What is the best way of doing this?
Would it be just to burn the data onto disk as it is or would it be better to rar as much as I can then back up?
Does that enable me to store more on the disks?
Thanks!
external Hard Disk and copy all your data on to it
this
what type of data is it?
if it's word docs and uncompressed bmp, avi, wav files then winrar will hugely reduce the size of the files
if it's mp3, divx etc then it'll make about 0.5% difference
i'd buy one or two icybox 390 enclosures and one or two hard drives (depending how much you value your stuff)
this
This.
And use robocopy to backup the data. (Thanks Bledd!)
I learnt the hard way on backing up important shizzle like photos - I now back up to DVD and then rar them up on a weekly basis (with password) then copy that to an offsite backup elsewhere like BQBackup or something like that as long term storage.
I was looking at the Amazon storage thing as well to make double sure!
If you are serious and willing to do some work learning how to use the software (and buy the hardware and software), get yourself a program called retrospect. it used to be made by dantz, but emc bought them over. it is superb, but there is a learning curve involved. You could also go for acronis, but you have less options, although it is a well respected piece of software. I use retrospect to backup all our data, and acronis to backup the system (windows installation). Also, partition your hard drive if you only have one, and keep your data on one partition and windows installation on another - that way, if windows crashes you can reinstall and your data will still be on the data partition. Even better - install one hard disk in your machine on which you will install windows, and another on which you'll keep your data.
And as mentioned above, you need an external hard drive. Get the biggest one you can afford.
We run a business and use retrospect to backup to multiple hard drives. Some are on site, and some are kept off site.
IF YOU'RE HARD DISK DIES AND YOU DON'T HAVE BACKUPS, AND YOUR DATA IS IMPORTANT, YOU'LL BE SORRY YOU DIDN'T BACKUP :D
Unless you only have a very small amount of data, forget about backing up to dvd. In my experience, dvds like to become corrupted. If you do back up to dvd, then make sure you get a copy of unstoppable copier (I think that's the right name anyway - it has recovered a few dvds for me).
Hope this helps.
