bledd. said:...and can be scheduled
MTA99 said:but not to run on shutdown or logoffhence robocopy for the logoff/shutdown win
bledd. said:sure you can
just use gpedit.msc to add it to startup / logoff / shutdown
synctoy.exe -R (will run all jobs)
synctoy.exe -R"Pictures" (will run the job called pictures if you have one)
JonRohan said:sync back is pretty good too. www.2brightsparks.com
MTA99 said:Do you speak from experience?![]()
bledd. said:can't say i've used it for logoff/shutdown, but the help file says it'd work
bledd. said:
does it do this with 1.4 aswell?
bledd. said:personally, i've used robocopy a lot, but synctoy seems more suited for the average home user
