Backplate for GTX 780 reference
22 Mar 2014
Plymouth
Hi there guys do you know anyone who is doing custom backplates for gtx 780 from EVGA GTX 780 SC ACX (Reference pcb). I would be thankful for your help
http://www.coldzero.eu/
He made these for me:
If I may ask how much did you pay? Also does he do any custom backplates or is it some sort of general template. Lastly how do you install it ? (is it like evga gtx 780 back plate where you just unscrew all screws except core one around gpu core?)
He does custom too, just make sure to provide him with a high resolution image (prefers vector files iirc) of what you want :)
Price is around £20 a plate including postage from portugal ;)
Watercool make metal ones, though you may need to source alternative mounting screws as the provided ones will be for use with a watercool waterblock.
The screws are like the original ones, just a tad longer. So you should be able to remove one, measure it or take it to a shop and see if they have some a tad longer.
Otherwise i'm sure Coldzero will give you the right name/size and u can find them on the bay.
