backplate help
15 Jun 2014
I am buying a new motherboard and cpu and I do not have to correct backplate for my motherboard. I require one for my h100i where can I purchase one what will come tomorrow?
Motherboard: ASUS*Z87-PRO
CPU: i5 4690k
Thanks for your help in advance! :)
I'd hold off on ordering anything at the moment
I'm pretty sure that my h100i came with the correct bracket for an 1150 cpu, it's the same one as the 1156 mount (you'll notice that the threads on the bracket are "adjustable")
Sorry forgot to say I had lost it.
Just looked on scan as I like quite close and the bracket kit for them is being released tomorrow. Will have to go tomorrow 10 pound for it note to self don't lend friends important parts! :-)
I just got a H80i not long ago and the bracket that came with it does fit socket 1150. I'd imagine it's the same bracket that will come with the H100i. I helped my boss install his H100 (or H105, can't remember exactly) and that bracket also fits socket 1150.
If you've already got the H100i and lost the bracket, get in touch with Corsair. One of the mounting screws for the pump is squint for my H80i and they had a new one sent out the same day I contacted them.
