Hi All,
We're currently using Backup Exec 11d, and we're trying to set up a new Backup to Disk job from a folder on a nightly basis, so from Monday night through to Friday Night. The job is approximately 200GB in size and takes about 3 hrs ish to run
I've set up the Backup to Disk folder with the following settings:
Max size for B2D files: 210GB
Max number of backup sets per B2D file: 100
Number of concurrent jobs for thie B2D Folder: 1
I've then set a media set as follows:
Overwrite protection period: 0 hrs
Append period: Infinite - Allow Append
The job is set up to use the correct device, in this case called 'Notts Backups' and is set to use the 'Notts Backups' Media set
The job is set up Append to Media, overwrite if no appendable media is available.
The disk they are writing to has 1.5TB of space, so should be enough to keep at least a weeks worth of backups, but when I'm looking in the folder at the *.bkf files they seem to be overwriting the files.
The issue:
I've obviously got a setting wrong here, as I want it to fill up the disk with each of the nightly backups, and then when the disk is full to overwrite the oldest of these files. Is anyone able to advise me which setting I've got wrong here, cause its confusing the hell out of me!
Thanks in advance!
The issue:
Thanks in advance!
