Backup & restore of system partition
Capodecina
30 Jul 2006
I have just tried using a demo version of Acronis True Image 11 to make an image of a freshly installed copy of XP on a laptop with a view to being able to restore quickly to a known "clean" state.
The problem I have encountered is that Acronis seems to insist on writing to a separate physical HDD (my laptop has a single 80Gb HDD). I tried using an external 320Gb USB HDD - Acronis wants to delete everything off that disk in order to be able to use it :(
In a prefect world, what I would like to be able to do is to make a copy of the 10Gb OS partition on a DVD and then quickly to restore it, overwriting the laptop OS partition.
It used to be possible with the command based Nero but I believe that the version I have doesn't work with NTFS or DVDs and that the current versions have so many invaluable added features that they are pretty much useless :mad:
Does anyone know of some software that will simply and reliable allow me to do this?
acronis can backup just one partition, i use it to make an image to the 2nd partition, then at a later date, can restore than back
don't click the 'clone' drive option, just click 'backup' and select just the partition in question, and not the 'mbr'
Thanks, just giving that a go, creating a .TIB file.
As a matter of interest, how do I run a restore? I will be overwriting the active partition :confused:
deffo the best way to do it
you can tell it to burn the tib to dvdr-s if you want, personally i'd hold it on your usb hard drive & the 2nd partition
it's a good idea to do things like this before making an image..
disable system restore
run 'ccleaner slim' on your machine
clears out junk then, so the images are smaller :)
i prefer making backups using the live-cd feature, just feels 'safer' than doing it in windows, and you need the cd to restore anyway
As bledd said, you're better doing it from a boot CD in case windows burps while you're backing up, but I don't bother me backside and it's given me no trouble (yet, although I've taken the p*** with what I've asked it to do a few times with no worries).
With restoring, again the boot cd is better, but it WILL do it from within windows (ish). It'll do something simillar to Ghost, write a temporary bootblock on the drive, boot into it and then apply the image.
I use acronis a lot to hot swap my Vista32 and Vista64 from within XP, and it works a treat. Not done me a wrong turn yet. The worst it's ever done is report an error about it having written the wrong number of bytes. I re-ran the operation and it finished fine.
Uhhhmmm, well that seems to work like an absolute dream. I'll give it a bit more testing before I bet my acceptance tests on it and then get back to work - thanks guys, that's saved me a bundle of time!
it's worth testing the restore, just incase :)
don't tick the 'restore mbr' or it'll want to format the whole drive it's restoring to
