Backup Tape Drive
27 Dec 2002
Worcestershire
Hi all
I have a choice of an LTO1 or DLT-V4 tape drive from a source. Which one should I go for and why? I know that DLt is going defunct and the most common system now is LTO, however the LTO1 only stores 100GB/200GB and the DLT-V4 stores 160GB/320GB
Thanks
Depends how much data you're backing up, if you dont need the extra capacity then the LTO is probably the better option.
You might get more useful replies in the servers/enterprise forum
