*edit edit* I think I'm an idiot... normal humans don't temp test with AVX versions of Prime. I even knew it was AVXing and said as much but somehow didn't remember that that's bad.
Now using Prime 26.6 (pre-AVX). 10 minutes, 12 threads, max 73c. Still in an open case, but it's a warm day and I'm pretty content with this after all. I assume the radiator is cool (well, 33 degrees now) because it is huge
Nothing to see here folks, move along!
Hi folks,
Just assembled a binned+delidded 8700K, Asrock Taichi and Corsair H115i Pro.
Thus far, it seems to be game-stable @5ghz with 1.312-1.344vcore, which is a good start! Runs about 50 degrees playing Ark survival.
But as soon as I hit Prime 95... this thing gets hot. Like 88 degrees after a few minutes so I stopped it. I have an AVX offset of -3, so it's running @4.7 during this. Seconds after ending the test, boom, down to 35 degrees.
This... doesn't feel right for the volts, the delid, and the 280mm top rad.
Corsair software says the pump and fans are maxed, but the water pipes and radiator do not feel as nearly warm as my old one used to get with a 1600X under it. Sticking a temp probe into my radiator suggests it's at 29-30 degrees. I've replaced Corsair's heatpaste with Kryonaut. No different. The metal brace behind the CPU socket is painfully hot to the touch. Running in an open case, ambient 24C.
I feel like something probably needs RMAing because heat just isn't getting away from the CPU, but I don't know whether it's the AiO pump or the delid that isn't right.
Advice appreciated...
*edit* Just 4-worker threads in prime = 75 degrees... Something is very wrong
Hi folks,
