Bad company 2 single ppl help!
10 Jul 2003
Birkenhead
hey all anyone wanna give me a idea how to get down the hill to the base below. if i go left or right says i'm going out of the map. cheers
I had the same issue when you where at the beggining of the map jumping in you missed a checkpoint. Go all the way back to start you will see it.
cheers will give it a go now
Edit : been all the way back and sniped all the bad guys
its just says find missing members when i;m already with them all
There should be a little wooden bridge just to the right you cross over and go down and around. All though i remember just parachuting off down the slope.
Yeh you go all the way back up the hill its where your meant to land, take them all out on way down and go the proper route and it will work. I had the same issue was damn annoying.
