Bad Company Gamertag Linkage: Temporary Fix! (Look Inside)
26 Dec 2004
Sweatshop.
Right i found it suitable to make a new thread, since LOADS of people are complaining about the issue.
A temp fix quite simple, allowing you to view your stats, and also unlock the free "find all five gun" so here it is.
It normally does work, everybodys i have tryed apart from one PS3 ID did not... I got the temp fix off somebodys idea off a Competitors Forum :)
1.Sign up to the EA Battlefield: Bad company website,
Do that here: http://badcompany.ea.com/
2.Once registered, Log in to the website.
3.Once your in, this is the very simple and last part.
Copy and paste the following into your browsers, address bar, making the necessary changes to the gamertag part.
PS3 ID Link:
http://badcompany.ea.com/myprofile/ps3/*put your gamertag here*/
Xbox Gamertag Link
http://badcompany.ea.com/myprofile/xbox/*put your gamertag here*/
SO! it should look like for an example!
http://badcompany.ea.com/myprofile/xbox/onlyneoni/
Thats it you can happily view stats, achievements etc the lot! without having to link your tag.
Hope this helps!
-Neoni
Glad i could help, everyones ive looked at works, whos on my friends list who wanted me to look.
Played for 21 odd hours. Didn't know i had played for that long, i haven't played it for about a week...
