Bad scores on benchmarks, help!
Screenshot doesn't work mate. You need to upload it to Imgur or similar, then do a link. We can't access your HDD...
To start with, get into control panel in Windows and make sure you're not set to power-saving mode.
Hmm. Yep, it's there, but pretty small and blurry..
Your RAM- is it in the correct slots on the mobo? Most will specify in the manual to use A2 and B2 slots for a dual-stick kit. You'll get bad performance if they're in A1 and B1.
This would in turn drag everything else down...
Might not be anything, but your SSD looks mighty full. They lose performance the fuller they get; might be worth moving some progs onto a different drive to free some space, then run Samsung Magician and Trim it.
Could we get a view from HWMon as well? It's a good hardware monitor and will show us temperatures and voltages, both of which could cause hardware throttling if there's an issue.
Can you post your system specs please, from what I can make out of that first image, your ram is what is seriously under performing in your system, looks like you have an Amd cpu, they have always preferred faster ram to get their performance up.
Which benchmarks have you run? What exactly were the results? Have you tried running the benchmarks with monitoring tools on a second monitor?
