![smartguardian7np.gif](http://img139.imageshack.us/img139/2706/smartguardian7np.gif)
Is there anything wrong here with the rails?
(ignore the CPU temperature, goes a bit haywire as its below 0°C)
but when its that low, does this suggest strain on the PSU ?fornowagain said:The spec is 5% + or -
12v looks low but in spec.
seriously?fornowagain said:I had the same PSU with the sig below and it wasn't up to the job. Changed it for a better PSU and my overclock went up quite a bit.
Heofz said:seriously?
Looks like its time for a new PSU![]()
how do i check with a multimeter exactly? which contacts do I use or does it depend on my motherboard?VaderDSL said:nooo the software is probably off - if you can check with a multimeter, then decide if you want to change, checking it with a multimeter will probably show a different reading higher or lower I couldn't say however.
