Recently i've developed a bad wobble rather than vibration when the engine is under load. It seems to be worse at lower RPM in a higher gear when the engine has to work hardest.
If i'm on the motorway and at 70, slow down to say 40 then accelerate again it's really bad, shakes the car + gearstick etc, and the wheel jitters. It doesn't feel like your average wheel unbalance.
It's like a low frequency wobble and again it's worse uphill. It won't do it at really low speeds or if i put it in neutral and rev at say 70mph it won't do it.
Engine mounts seem fine (only one I haven't checked is dogbone, but it looks ok)
Driveshafts were changed not long ago.
Wheels were balanced with new tyres about 3 weeks ago.
Tracking is a tiny bit out (had it tracked about 1month a go)
New wishbones + balljoints not long ago
Don't think discs are warped but does it when driving normally anyway
Wheel + hub nuts ok
Anything else I can check or recheck as it's making motorway driving a nightmare!! Also this may sound daft but it seems to get worse after it's been driven a bit?
Any help appreciated!
Wheel + hub nuts ok
