After having several unresolved problems with my router, I decided to share the internet connection from a PC gateway instead of sharing it from the router modem.
I've had a look at Baddass' guide, and it says that main pc IP has to be used on the other PCs when setting up the connection sharing. I went through Windows Network Wizard, but it tells me that 192.168.0.1 is needed to setup this computer as the gateway. Problem is that this IP is used by the router to be able to access it and change the seetings, and I don't know what else.
I'm not sure where to head from here. Any suggestions?
