Hi, my PC randomly crashes while general internet browsing or while gaming.
It would stall then restart. No blue screen, just a straight crash.
I have a temp monitor on the 2nd screen so I can see immediately what the temps were at time of crash. At every crash the 2080Ti has not gone above 40 Celsius.
I have DDU'd at least twice, applied different drivers in attempt to resolve it (Dec, Jan, Feb and March Nvidia drivers.)
If anyone is wondering my PC is this https://www.overclockers.co.uk/ocuk...700k-4.6ghz-geforce-rtx-2080ti-fs-1b8-og.html
Below is the report from WhoCrashed app. (It actually crashed yesterday, 8/3/2020, but for some reason a dump wasn't generated.)
Any ideas?
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Mon 09/03/2020 16:39:24 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\030920-7921-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF801413D897A)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF801413D897A)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_33895c186dfc2a0d\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 442.50
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 442.50
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 442.50 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation DRIVER_IRQL_NOT_LESS_OR_EQUAL
crash dump file: C:\Windows\MEMORY.DMP
On Sun 23/02/2020 22:14:56 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\022320-9750-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF807225D8ACA)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF807225D8ACA)
On Wed 19/02/2020 20:09:01 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021920-7687-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF80389298BDA)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF80389298BDA)
On Tue 18/02/2020 23:45:32 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021820-9890-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8067DC58BDA)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF8067DC58BDA)
On Mon 10/02/2020 19:31:56 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021020-10265-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8036D898BDA)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF8036D898BDA)
Conclusion
6 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Any ideas?
C:\Windows
C:\Windows\Minidump
Conclusion
