Hi
I'm looking fo a 4G router that can use multiple 4G connections at the same time to get a stronger & faster internet connection.
I have a 4G router that can get 20mbps on EE, and has a dual sim, but it's for failover (e.g. when one sim runs out of data it will switch to the other).
But I would really like one whic I can use multiple EE sims and even different network sims to achieve a far greater internet connection.
A question I have though is if 2 EE sims connect at the same time from the same location, is the total bandwith shared between the sim card or will they both have independant speeds (say 20mbps) and total 40mbps combined speed?
