Balanced enough ?
27 Dec 2012
London
Good day everyone!
A friend of mine wants to buy a new gaming pc and he asked me to help him build one, therefore i went forward and made a custom build since he does not want to assemble it by himself (won't be around to help him). Please let me know if this is a good enough build and if it's well balanced to allow him to play next gen games at high/max settings for the next maybe 2 years without changing anything inside.
Overclockers can build you a pc from your own spec. So for example.....
YOUR BASKET
1 x Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£43 Saving** £347.99
1 x AOC G2460PG 24" Widescreen G-Sync 144Hz 1ms Gaming LED Monitor - Gunmetal £319.99
2 x Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card £259.99 (£519.98)
1 x Crucial MX100 512GB SATA 2.5” 7mm SSD + 9.5mm Adapter CT512MX100SSD1) £154.99
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £99.95
1 x Cooler Master Nepton 280L, AIO Cooling Solutions £87.95
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £60.98
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
Total : £1,904.42 (includes shipping : £22.20).
The GTX970 is almost as fast as a 780ti.
24" G-Sync Monitor
Coolermaster AIO will perform a lot better than the H80i.
EVGA psu is much better than the Corsair RM.
So if you go to the Customer Services section you can post any basket in there and then they can give you a quote to build it for you. You can also ask them about overclocking it too if you want.
Use the shopping cart plugin to post your spec - https://chrome.google.com/webstore/detail/ocuk-shopping-cart-viewer/empfloiadabicdlgahhamannadefhehj
Other browsers - http://forums.overclockers.co.uk/showthread.php?t=18371076&highlight=browser
Thanks mate ! I had no idea they can build it with your own specs and you're right, the suggestions you made are a much better deal for the purpose. :)
