At the moment I am set up as follows:
I've made the move to balanced headphones, which is easy for mobile use as I've got the Fiio Q1 mk2. However I'm looking to swap the
desktop SD793 for something that has a balanced headphone out while retaining the inputs and preout/monitor drive requirement.
The only devices I've seen that don't completely nuke my budget are:
Topping DX7s - http://en.tpdz.net/products_detail/productId=32.html
This ticks the boxes on the input front and the balanced headphone out. However I'm reading this has line out rather than pre-out, I can't work out if that is going to be an issue with the powered HS5 monitors? If it works then the XLR output is a bonus as can run that to the HS5.
SMSL M9 - http://www.smsl-audio.com/productshow.asp?id=108
Less inputs, will have to move the PC to USB rather than optical. But does have a pre-out mode. It's definitely an ugly duckling though.
Is there anything else I should be considering? The M9 comes in at £375 (Amazon pricing), the DX7s is trickier to locate and probably imported via AliExpress for roughly the same price.
Cheers chaps![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Cheers chaps
