Ballistix pc3200 problems
6 Apr 2006
Hi all,
I've had these 2 512mb PC3200 Ballistix RAM (SPD 2-2-2-8) for 1.5 years now. My motherboard is Asus A7N8X2.0 Platinum with a AMD Barton 2800 running at 10.5 X 200. Everthing else besides the CPU is running at stock speed with no overclocking.
My PC has been getting around 1 blue screen a day, and various other weird application/game crashes for as long as I can remember.
Since gotten this PC together 1.5 years ago, I've got better knowledge on how everything works so I decided to look into this problem.
The first tool I used was windows memtest, and that gave me errors after around 2 or 3 minutes in. So I started changing the RAM setting in BIOS:
- change from the SPD timing of 2-2-2-8 to 3-7-7-12 or more
- voltage from 2.6 to 2.8
- speed from 200 down to 166
- swap the 2 sticks around so they work in single channel
- leave only 1 stick of 512mb on the motherboard
- upgraded BIOS to the latest 1008
...... and memtest still gives me errors, albiet a bit less than before.
Just to verify that it's not the motherboard that's at fault, I installed a 512mb OCZ pc3200 RAM I had lying around, and that works fine with memtest... I'm a bit sad because I thought I payed extra money for Ballistix at the time for precisely the reason for this NOT to happen :(
Do you guys have any suggestions of what I could try next? Or does this mean that there are problems with these 2 sticks and if so do you think they (I bought them from the crucial website) RMA these even after 1.5 years?
You have a lifetime warranty, and your stick(s) certainly sound dead. If you can I'd try them in another PC just to be sure but Crucial are pretty good when it comes to RMA's. Give them a call and they'll sort you out.
try each stick individually. could be that just one stick is gammy.
than again nforce 2 boards are a real pain when it comes to memory.
another ballistix failure?!
do yourself a favour, ask crucial for your money back, and get some corsair...
ive had 10 ballistix Dimms fail on me, and SO glad i got these corsairs dimms now.....
