| Item | Specification |
| | Printing Technology | Fused Deposition Modeling |
| Body | | |
| | Build Volume (WxDxH) | Single Nozzle: 325x320x325 mm³ |
| | | Dual Nozzle: 300x320x325 mm³ |
| | | Two Nozzles: 350x320x325 mm³ |
| | Chassis | Aluminum and Steel |
| | Outer Frame | Plastic and Glass |
| Physical Dimension | | |
| | Physical Dimensions | 492x514x626 mm³ |
| | Net Weight | 31 kg |
| Toolhead | | |
| | Hotend | All Metal |
| | Extruder Gear | Hardened Steel |
| | Nozzle Material | Hardened Steel |
| | Max Nozzle Temp | 350 °C |
| | Included Nozzle Diameter | 0.4 mm |
| | Supported Nozzle Diameter | 0.2 mm, 0.4 mm, 0.6 mm, 0.8 mm |
| | Filament Cutter | Built-in |
| | Filament Diameter | 1.75 mm |
| | Extruder Motor | Bambu Lab High-precision Permanent Magnet Synchronous Motor |
| Heatbed | | |
| | Material | Flexible Steel Plate |
| | Included Plate | Textured PEI Plate |
| | Supported Plate Types | Textured PEI, Smooth PEI |
| | Max Heatbed Temperature | 120 °C |
| Speed | | |
| | Toolhead Max Speed | 1000 mm/s |
| | Toolhead Max Acceleration | 20,000 mm/s² |
| | Hotend Max Flow Rate | 40 mm³/s |
| Chamber Temperature Control | | |
| | Active Heating | Supported |
| | Max Temp | 65 °C |
| Air Purification | | |
| | Pre-filter Grade | G3 |
| | HEPA Filter Grade | H12 |
| | Activated Carbon Filter | Granulated Coconut Shell |
| | VOC Filtration | Superior |
| | Particulate Filtration | Supported |
| Cooling | | |
| | Part Cooling Fan | Closed Loop Control |
| | Cooling Fan for Hotend | Closed Loop Control |
| | Main Control Board Fan | Closed Loop Control |
| | Chamber Exhaust Fan | Closed Loop Control |
| | Chamber Heat Circulation Fan | Closed Loop Control |
| | Auxiliary Part Cooling Fan | Closed Loop Control |
| | Fan Type | Closed Loop Control for Part Cooling, Hotend, Main Control Board, Chamber Exhaust, Heat Circulation, Auxiliary Cooling |
| Supported Filament Types | | |
| | PLA, PETG, TPU, PVA, BVOH | Optimal |
| | ABS, ASA, PC, PA, PET | Superior |
| | Carbon/Glass Fiber Reinforced PLA,PETG, PA, PET, PC, ABS,ASA | Superior |
| | PPA-CF/GF, PPS, PPS-CF/GF | Ideal |
| Sensor | | |
| | Live View Camera | Built-in; 1920x1080 |
| | Nozzle Camera | Built-in; 1920x1080 |
| | BirdsEye Camera | Built-in; 3264x2448 |
| | Toolhead Camera | Built-in; 1920x1080 |
| | Door Sensor | Supported |
| | Filament Run Out Sensor | Supported |
| | Filament Tangle Sensor | Supported |
| | Filament Odometry | Supported with AMS |
| | Power Loss Recovery | Supported |
| Electrical Requirements | | |
| | Voltage | 100-120 VAC / 200-240 VAC, 50/60 Hz |
| | Max Power | 2200 W@220 V / 1320 W@110 V |
| | Average Power | 1050 W@220 V / 1050 W@110 V |
| Electronics | | |
| | Touchscreen | 5-inch 1280x720 |
| | Storage | Built-in 8 GB EMMC and USB Port |
| | Control Interface | Touchscreen, mobile App, PC App |
| | Motion Controller | Dual-core Cortex-M4 and Single-core Cortex-M7 |
| | Application Processor | Quad-core 1.5 GHz ARM A7 |
| | Neural Processing Unit | 2 TOPS |
| Software | | |
| | Slicer | Bambu Studio; supports third-party slicers (e.g., Cura, PrusaSlicer). Some advanced features may not work on 3rd-party. |
| | Supported Operating System | MacOS, Windows |
| Network Control | | |
| | Ethernet | Not Available |
| | Wireless Network | Wi-Fi |
| | Network Kill Switch | Not Available |
| | Removable Network Module | Not Available |
| | 802.1X Network Access Control | Not Available |
| Wi-Fi | | |
| | Operating Frequency | 2412-2472 MHz, 5150-5850 MHz (FCC/CE) |
| | | 2400-2483.5 MHz,5150-5850 MHz (SRRC) |
| | Wi-Fi Transmitter Power (EIRP) | 2.4 GHz: <23 dBm (FCC); <20 dBm (CE/SRRC/MIC) |
| | | 5 GHz Band1/2: <23 dBm (FCC/CE/SRRC/MIC) |
| | | 5 GHz Band3: <30 dBm (CE); <24 dBm (FCC) |
| | | 5 GHz Band4: <23 dBm (FCC/SRRC); <14 dBm (CE) |
| | Wi-Fi Protocol | IEEE 802.11 a/b/g/n |
| 10W Laser Module | | |
| | Laser Type | Semiconductor Laser |
| | Laser Wavelength | Engraving Laser: 455 nm ± 5 nm Blue Light |
| | | Height Measuring Laser: 850 nm ± 5 nm Infrared Light |
| | Laser Power | 10 W ± 1 W |
| | Laser Spot Dimension | 0.03 mm x 0.14 mm |
| | Working Temperature | 0 °C - 35 °C |
| | Max Engraving Speed | 400 mm/s |
| | Max Cutting Thickness | 5 mm (Basswood Plywood) |
| | Laser Safety Class for Laser Module | Class 4 |
| | Overall Laser Safety Class | Class 1 |
| | Engraving Area | 310 mm x 270 mm |
| | Processing Height Range | 0 mm - 280 mm |
| | XY Positioning Method | Visual Positioning |
| | XY Positioning Accuracy | < 0.3 mm |
| | Z Height Measuring Method | Micro Lidar |
| | Z Height Measuring Accuracy | ± 0.1 mm |
| | Flame Detection | Supported |
| | Temperature Detection | Supported |
| | Laser Module Installation Detection | Supported |
| | Engraving Timelapse | Supported |
| | Safety Key | Included |
| | Air Pump | Built-in; 30 kPa, 30 L/min |
| | Ventilation Pipe Adapter Outer Diameter | 100 mm |
| | Supported Material Type | Wood, rubber, metal sheet, leather, dark acrylic, stone, and more |
| 40W Laser Module | | |
| | Laser Power | 40 W ± 2 W |
| | Laser Spot Dimension | 0.14 mm x 0.2 mm |
| | Max Engraving Speed | 1000 mm/s |
| | Max Cutting Thickness | 15 mm (Basswood Plywood) |
| | Engraving Area | 310 mm x 250 mm |
| | Processing Height Range | 0 mm - 265 mm |
| Cutting Module | | |
| | Cutting Area | 300 x 285 mm² |
| | Drawing Area | 300 x 255 mm² |
| | Supported Pen Diameter | 10.5 mm - 12.5 mm |
| | Cutting Mat Type | LightGrip and StrongGrip Cutting Mats |
| | Blade Type | 45° x 0.35 mm |
| | Blade Pressure Range | 50 gf-600 gf |
| | Max Cutting Thickness | 0.5 mm |
| | Blade and Pen Recognition | Supported |
| | Cutting Mat Type Detection | Supported |
| | Supported Image Type | Bitmap and Vector Images |
| | Supported Material Type | Paper, vinyl, leather, and more |
