Bandicam Stuttering
21 Jun 2023
Cheshire
Hi,
I am using Bandicam but i keep having a frustrating issue with it.
Game FPS is flying (145+) but when replaying the recorded footage, its extremely jittery. I had a much worse comp than my new one and that never stuttered even at the same resolution.
think i may have got it working under game capture mode.
looks a bit dark on play back though, should be able to fix that on Sony Vegas.
Yeah, I’d definitely use game capture. If you do still have problems try running bandicam as an admin, that way it has permission to adjust the priority of the process.
Out of interest what game are you capturing? Or were you getting the problem with all game captures?
ok may give that a whirl.
another thing im struggling with is that the recordings keep corrupting and i have to run bdfix to get at them. They are not jerky anymore though.
Are you on the latest version of Bandicam? Just checked and strangely enough there's a update which seems to be dated today, not clear that there are any performance related fixes, but could be worth trying
7.1.0 02/19/2024​
  • Added the 'All display' option in the scheduled recording settings window.
  • Added an option to exclude Bandicam windows in the recorded video.
  • The Bandicam window size now automatically changes when moving according to the monitor DPI scaling.
  • Bugs fixed
    • The mouse clicks did not work where the keystroke overlay was displayed.
    • The Default size option in the DPI scaling option was unchecked by default.
    • Other minor bugs have been fixed.
