Won't your insurance company want a certificate of installation? In which case you don't have any choice,
Otherwise it depends on the type of kit, some are exhaust whilst some are carbs, unless you know what you're doing they can both throw up problems, but on the other hand if you know what end of a spanner to hold and some basic mechanical skills it's also quite trivial to install/remove them...
