- 28 Jun 2003
- The Moon
Hi All,
I need help to traffic shape my blue zone on my firewall.
I want to throttle the bandwidth for a single IP number and not ports it is using.
I am running IPCOP V1.4.13.
I have the following setup,
Green Zone for my Internal LAN
Blue Zone for my wireless LAN, (ie my neighbor)
Red Zone contact to the outside world.
Basically if my neighbor is downloading stuff but I want to surf or take priority I want a fast way to lower his bandwidth.
There is a traffic shaping facility on in IPcop but I can’t seem to get it to do what I want. It does not seem to discriminate which zone you are throttling, I think it does it across the board to all zones.
It also only seems to accommodate for individual ports where I would like to just throttle an IP number.
Can I perform this from the existing options in IPCOP or can a bit of code be edited to achieve the desired result.
I am not super smart/code orientated but if given clear instructions I can implement them.
Can anyone help?
Can anyone help?
