Bang for buck gaming pc ~£1k
23 Sep 2010
Not just reasonable, it is required nowadays.
You can get 32GB for like..., £15-£25. I'd do it. 8GB sticks have outlived their usefulness.
Is this a prebuilt PC? Was just wondering why it has the Kolink Classic.
Yes good point on the RAM, I can't believe how cheap it is now. Will get the 32GB version of the same model instead: https://www.overclockers.co.uk/team...4-pc4-25600c16-3200mhz-dual-ch-my-0aj-tg.html
I'm not sure why I chose that particular PSU, I might have sorted by most sold. Can definitely swap it out if you recommend?
Thanks
Yeah, I'd swap it out for something much more heavy duty, more like this one.
If you're happy to brand switch then (review of A750GF here and RMx here):
My basket at OcUK:
Total: £209.99 (includes delivery: £0.00)​
My basket at OcUK:
That Corsair looks lovely, well worth it by the sound of that review. Compared to the bronze rated Kolink I might get back some of the money in power savings over the years as well.
Not a bad build for a grand! I'll be very happy with it for quite a while anyway. Thanks for the help.
