Bang for buck spec to house 3080
19 Dec 2017
I embarked in an experiment to try and pair a 3080 with an unused laptop via an egpu enclosure and it was a failure. I posted about it here
Anyway, onto the next steps - I want to build a PC that focusses of price : performance over cost or performance alone. I think what that looks like is a low-end 7000 series cpu (it didn't seem to save much going to 5000)
But I haven't looked at hardware since 5000 series dropped, am I on the right course here?
My basket at OcUK:
Total: £710.94 (includes delivery: £11.98)​
It would, a 5600 non-X is a lot cheaper than the 7600 and the board/DDR4 can be found cheaper too, but it comes down to future upgradability really, if you think it's worth paying more for AM5. Don't think the 5600 comes with a free game either.
You might want to get a PSU which is ATX 3.0 with a native 12/16 pin.
The case: I'd check the PSU max length and the GPU max length.
What took you so long? :cry:
Thanks for the advice.
I see my mistake, I was comparing 5600x with 7600. I still think the difference in cost is worthwhile to get something current gen to open up that upgrade path a little.
I pulled the trigger with an adjustment to an ATX 3 psu but sadly OCUK was not the cheapest of the larger pc component suppliers. I don't normally mind paying a little extra for the service, but this was not insignificant :(
Well, all together now and I'm super happy with the results.
Some slight tweaks were Asus PRIME AP201 because that seemed like a better solution thermally and a worthwhile trade off for a bit of noise, if I was going to go MATX. Also found a Peerless cheap on Amazon.
End result seems to be a real solid performer for little over £900.
