Bang for buck upgrade
26 Aug 2005
London
I have a 2500K i5, 8GB of RAM and a 4790 ATI (which has lasted me quite a while as I'm a casual gamer). Unfortunately this GFX doesn't support some of the newer games and I've itching to play the new Batman.
I'm thinking of buying a bigger CPU cooler and a second hand GFX although I'm not sure what to get exactly. I was thinking about a 670 GTX but I heard RAM on these isn't quite enough.
What do you recommend?
£70-£100 for GFX and £20 for CPU cooler.
Screen resolution 1900x1200. PSU is a Corsair 580w series I believe. Case is a cooler master praetorian.
You might find a 280X for that price.
And a Raijintek Aidos should fit your case, they are £15.
Personally, I'd just spend all the money on the GPU and forget about the CPU cooler as you're not likely to bottleneck any ~£120 second hand GPU with a 2500k at stock settings.
OK - what does £120 get me?
And I was under the impression that overclocking the 2500k gives quite a big performance increase?
