anybody had this done? How much did you pay?
I’m thinking about having it done rather than spend the next 3 months stripping and sanding I could do with a ball park figure before I decide to get a proper quote
How can anyone guess without even a suggestion as to the size of the job?
What length, how many spindles, what type of wood. That's for starters!I dunno , how do you size it up? it’s an Average staircase in an average terraced house
Would be cheaper to pay someone to prep and paint it nicely!
I've just replaced my handrail and spindles into my loft room. From memory the 3.6m oak handrail cost £150-£200 and the spindles were about a fiver each (just softwood as I painted them white)
I'm just about to do my main stairs but it's proving to be a lot more expensive as the original handrail goes up the stairs, turns back on itself, then goes up 3 more stairs to the landing, then across the landing and finally does a 90 degree turn to the loft room door. I've had a few people out to give me a quote and they've all sucked in air through their teeth and said "that's gonna be expensive" and none have got back to me with a price so it doesn't look promising.
For a large 4 bed ours was 1k cash to a chippy. In oak and all bespoke made by him. Looks great
Was it straight sections or any curved bits? From what I can tell it's the curved bits like this on mine that make it expensive
I'm currently doing the same thing. Getting the several layers of paint off with a heatgun is pretty easy but it's the woodstain that causes the problem, it ends up in a big gloopy mess on the scraper most of the time :/.
If I can't get all of it off I'm probably going to end up buying some Langlow Strip Away Pro. From what I understand this is proper old school paint stripper not the waterered down modern stuff and is technically banned under EU law (e.g., it must be good). If you do end up getting some you do need to wear rubber gloves, cover your arms, wear goggles, and work somewhere well ventilated (setup a fan) because it is dangerous stuff in an enclosed place!
