Thanks for all your replys, Exactly what i want to do is Have 2 columns in an excel document, 1 with stock number and 2 with shelf number, Is there a way to get the card reader to decipher between the 2, so for instance, I put 10 items on a shelf and scan each one individually then at the end i scan *** shelf number, I want the stock numbers to be in column 1 and the shelf number to be in column 2 automatically?
The hardware i am planning on using is a PDA with an SDIO card reader.
Thanks for the help so far
