Barebone System
18 Aug 2009
Yo' everyone
(quick life story) this is my first time building a pc from pretty much scratch and just need to know what to expect next...
i've just purchased the barbone system on OCUK, http://http//www.overclockers.co.uk/showproduct.php?prodid=FS-176-OK may i mention that i had the duo core e7400 2.8ghz & 4gb of ram installed aswell.
So i've installed all the connectors to the correct slots, i've also purchased a new 500gb 3.5 hard disk, optical drive and windows vista
Anyway back to my question once i power up the computer, what am i expecting to see next? Will i have to configue something in the BIOS? bearing in mind that its a new hard drive when will the formatting be done? and then finally installing vista?
Any video's, any step-by-step guides, web pages links will be most appriciated.
thanks in advance
Put your OS disk in and boot up.
A message asking if you want to boot from disk should come up (you do). If not then reboot and enter the BIOS, set it to boot of the disk drive and restart.
Formatting is done within the OS instillation process.
After installing OS its a good idea to set the boot priority back to HDD.
/thread
:p
Quick update if anyone cares lol. I've placed everything correctly i.e. the connectors hdd etc...and i plug in my VGA Acer screen to the pc's back panel port...boot the computer up and nothing appears on the screen. HEEEELLLPP!!!
It seem's everything is fine, i just need someone to point me in a direction if any direction acutally. So, any clues what it can be? bearing in mind that it has installed graphics chip on the motherboard and my Acer screen has never failed on me. The pc back panel has a DVI and VGA slot, i also got a VGA-to-DVI adapter to see if that would work but no luck at all.
any idea's?
Its worth trying, although unlikely.
Can you post up a few pics of the build ?
Make sure every connector is in securely, and that you havent missed any.
hhhm, i can't find anything there that helps me my friend. i shall post an update for trying a different monitor soon..
