Hi guys, first forum post here. Thought I would join up as I have a burning question about an upgrade and I figured there would be some people on here that know stuff about stuff. So here goes:
About 18 months ago I decided to build my first gaming PC on a somewhat meagre budget, basically I was bored with my Xbox and wanted something with a bit more firepower. So, this is what I built:
Asus P8H61-mx USB3
Intel G850 dual core
8Gb 1333Mhz
1 Tb 7200 rpm HDD
Coolermaster 80+ 600W PSU
Radeon HD 7850 2Gb Sapphire OC edition
For my first build I've been pretty pleased with the result and it's certainly resulted in my 360 collecting dust. However, I've been seeing all these shiny new consoles coming out and I'm conscious of the fact that my humble rig does struggle with a few titles (Battlefield 3/4, Crysis 3, Rage, to name a few). A bit of research indicates that these games in particular like a few more cores to run at their optimum. Ultimately I would like to at least be able to compete with an Xbox One/PS4. My dilemma is that I have a strict budget of £150, soooo, this is where you clever and knowledgeable folk come in:
My possible options are:
1. Intel 3350p (will fit right in my mobo, costs about £130)
2. Intel 3470 (again will fit in, slight boost in speed over option 1, costs £145)
3. FX 8320 + mobo (Like the idea of 8 core, bearing in mind that console based games will be based around this architecture, however, the CPU is £115, which only leaves me with £35 for a bottom range board - is this even worth considering?).
4. Any alternatives that you guys may be able to suggest.
With the Intel chips I have stayed away from the default 3570K, as it would be wasted on my motherboard.
Sorry for the wall of text, but I figure with a question such as this, less is not necessarily more.
Thanks for your help.
Asus P8H61-mx USB3
8Gb 1333Mhz
1 Tb 7200 rpm HDD
