Barrow DDR5 waterblock
17 Nov 2008
Black country
Just brought it off chineese site going to fit to my Gskill 8200 Cudimm as im getting errors when they hit 50c and there is a masive 10 degree difference between dimms
have heard the heat spreader on gskill insulate in stead of dissipate heat brought a jonsoon or what ever is called ddr fan made no difference
Has any one got one of these or another make what sort of cooling to exspect what would be the best size pads to use?
Usually 1mm for single sided sticks or 0.5mm for double sided.
I’ve used the iceman ram blocks. Temps were 3-4c above coolant temp.
Gskill heatspreaders are surprisingly easy to take off. Leave it running karhu for a bit and then you can peel them off by hand.
Most of the new heatspreaders have a thermal pad on the PMIC now so surprising a fan on the stock heatspreaders is not helping.
@momo56 there was a thermal pad on memory chips as well as the PMIC.
but the sticky thermal pad on the chips does not transfer heat very well seems to absorb heat had to use heat gun to get them apart.
waterblock heat spreaders are like triple the weight of originals
Well that never ended well one module gave up the ghost was gutted. But ended up with some 9000 cudim. Put these under water temps usually under 30c bench memory brings it up to 33c.
