- 22 Sep 2020
Hi all I have just installed the Barrow Digital OLED Display Flow and Temperature Sensor its showing temp but not flow it just says 0 any one got this item and not what I can do to fix it
Need to swap the internals around as it will only read flow in one direction. If it’s the same as mine I think there’s 4 screws on each end and it comes apart.
ThanksNeed to swap the internals around as it will only read flow in one direction. If it’s the same as mine I think there’s 4 screws on each end and it comes apart.
