Barrow reservoir issue
30 Nov 2010
UK
I purchased one of these a few weeks back and when installing I was forced to use an of-centre port as I was unable to fit either a Bitspower compression fitting or an XSPC 1/4 extension in the recessed centre hole.
I would like to drain/re-install the res using a centre drain port but not sure on what I can use that would fit in there. (nothing in manual about it). It’s like a big button cover that goes over the centre and sits flush but the hole and thread are typical ¼.
Any advice would be appreciated
I just realised the issue, looking at the product photo again one side only has one hole and three plus fill port on the other end. I was sent one with three holes plus fill port on both sides.
