Caporegime
- 13 May 2003
- Warwickshire
I've overclocked my Barton 2500+ to nothing staggering - it's at 200 x 10 so 2 GHz. However, at idle, my ABit monitor program says that the temp is 57 degrees C. This to me seems very high, especially since the case is off and there's a case fan. The cooler is a fairly decent aftermarket Speeze job with large fan and copper heatsink.
Does something seem wrong here as with an overlock of only 200MHz I wouldn't expect such high temps. If I take it any higher and play a game the machine shuts down with a high/low siren type beeping. I've even disabled temp-related shutdown. Voltage is slightly higher than stock at 1.675V.
Thanks for any opinions. Perhaps I need to check heatsink seating?
