*edit* Should stop been lazy.
Well basicaly
Genis Bios Settings Has all the settings for the CPU, HT, Multi, Voltages and then a sub menu for the memory.
FSB frequency- This is the speed at which the memory will run at if at stock settings.
CPU/FSB Ratio- This is your multi FSBxMutli = CPU clock speed
EG 2.0GHz 200x10 is your 3800 X2
Thats the basics
Voltages
CPU VID - CPU voltage
CPU VID Special - this is the multi for the CPU voltage....dont mess with this
LDT V - Think its the Hyper transport tech voltage
Chip set - Northbridge voltages
DRAM v - Memory voltage
Memory
DRAM frequency - this is the divider on the RAM
A divider of 1:1 will run the memory at the speed of the FSB
Command Per Clock - T1, T2 Run it at T2 unless you have 3,4 sticks of RAM
CAS Latency - First number in timings
2-3-2-5
RAS to CAS - second number in timings 2-
3-2-5
Min RAS - fourth number in timings 2-3-2-
5
Row Precharge - third number in timings 2-3-
2-5
The graphics card is all overclocked in windows via ATI overclocking programs, im no help in this area because iv only got an Nvi card and its totaly different programs to ATI.
