Basic Apache Setup
9 Dec 2004
Dorset
Hey,
I'm trying to set up a web server on CentOS 4.4. I've got apache configured and my content in the root of the webdir (/var/www/html/). This works fine.
I've then tried to add in webalizer to the mix, so I can view my site stats. I've placed the usage directory (containing the webalizer pages) into /var/www/html/usage/). I want to lock down that to my LAN IP address, so in /etc/httpd/conf/httpd.conf I have;
<Directory "/var/www/html/usage">
Options None
AllowOverride None (I dont want to use .htaccess files particularly)
Order Deny,Allow
Deny from All
Allow from 192.168.0.2
</Directory>
Save and reload apache. I then try to access that page from my LAN machine and I get 403 error. If I SSH onto the webserver and load up a browser, then type in;
http://my_server_ip/usage/index.html
I get the same problem. If I use;
http://localhost/usage/index.html
It works! ?!?!
I've set Apache to listen on eth0's IP, and normal content in the root web directory works ok :confused:
Any ideas please? am I missing something very simple? I didn't have this problem on my old SuSE server.
I'm placing this directory statement directly below the statement for the root web directory.
Ugh, turned out that when installing webalizer on RH it knows where the include confs directory is, so it puts a webalizer.conf into it. This then restricts to localhost only by default I believe, so hence my problem!
Solved :P
