Hi all, this won't be a build for me but it will replace an outdated Windows XP machine. Primarily for office tasks and simple (not 3D) games, but a fast boot up is desired. Current PC has only 60GB of hard disk used so the 250GB storage should be ample; using 2 drives (as I do in my machine, SSD and HDD) will be confusing for who this is for.
I generally find fewer problems building and setting up a machine if it has some sort of graphics card rather than on-board, plus gives it gives the potential to run some 3D games if ever desired.
I'm a little concerned the 450W supply isn't yet tested Haswell compliant, but what does this mean in operation? That sleep mode is unavailable, or that it uses more power in sleep than it should, or something worse? Apparently just adding a little load to the 12V line cures any issues, a fan is suggested but I can add a resistor onto a spare cable no problems, 100mA draw should do?
Any idea about that case? It's very cheap but I think a decent brand. It does need to be small to fit where it goes. I would probably add a rear case fan, likely Arctic F9 92mm. Otherwise I should be OK for hardware?
Might get a SATA cable, I think I have some around anyhow, unless they aren't Rev3.
CPU cooler isn't essential providing the retail cooler is decent/quiet. If it's 4-pin PWM control then I think it'll be quiet enough.
Let me know your thoughts!
Thanks
Thanks
. Also got a better CPU cooler, same as I have, Arctic Cooling Freezer Pro 7, it'll fit OK in the small case and gives overclocking potential if the system feels slow in the future.
