13 Sep 2006 at 15:39 #1 jase555 jase555 Associate Joined 18 Oct 2002 Posts 743 Location up north ok guys , just got my arctic cooler, have my 6300 and p5b board, roughly is it just like changing fsb to 400 and hit the voltage to * 2 or am i being stupid !!!! jase
13 Sep 2006 at 16:25 #2 DreadNiK DreadNiK Associate Joined 20 Mar 2006 Posts 692 read some guides, you probably want to disable some options in the bios and probably not jump straight to 400
13 Sep 2006 at 18:46 #3 Rab Rab Associate Joined 21 Oct 2005 Posts 1,049 Location Scotland take it slow, rushing will just cause u hrs of headaches . go thru the overclocking sticky on forum, get familar with it, then oc g/l
13 Sep 2006 at 20:51 #4 fs123 fs123 Soldato Joined 4 Feb 2006 Posts 3,421 I had to update my bios on my board to 0614 to get a stable clock speed of 3.09 GHz. The 0507 bios gave all sorts of problems with the DDR2. You can try setting to 400FSB but DO NOT double your voltage!! I wouldn't go higher than a Vcore of 1.55V unless you have very good cooling. If the pc fails to boot at a high FSB then you have you clear the CMOS or else you will have problems booting even at a lower FSB....
