i'm finding it hard to understand how to position divs where i want them using css on my page.
1. can someone explain why you couldnt just position divs using abs all of the page ??
2. if 1 is not right, then how should you do it ? placing on div using abs. then use rel to position the rest ??
and alsoo
can u explain why on http://suki.vidahost.com/home.html . when the window is small smaller the divs bunch up. but on http://suki.vidahost.com/div.html . they dont . even thought i use the same way of positioning
thank you for help
and alsoo
thank you for help
